FAQs about the MEDION Service App
fast & easy - free of charge & secure - directly from the manufacturer
  • What is the MEDION Service App?
  • MEDION Service appMEDION Service app
    Our service app for Windows and Android devices tests your product for all possible sources of error and delivers a result directly. Simply download it to your device, start it and if an error is detected, you can directly initiate a repair order.
  • For which operating systems is the MEDION Service App available?
  • Android_Logo    Windows_Logo
    Our service app is currently available for Windows and Android devices.
  • Where can I download the MEDION Service App?
    play.google.com/store/apps/details?id=medion.consumer.android
    System Requirements:
    Android 4.1 (Jelly Bean) or higher
    Windows_10_Logo
    medion.servify.tech/MedionServiceApp.msi
    Windows 10 / 11 64bit .net Framework 4.6.1
  • Can I perform the fault diagnosis without the app?
  • Yes, you can perform online fault diagnosis at any time.
Version history
Last update:
‎07.09.2022 08:58
Updated by:
Retired
Labels (3)
Contributors
