My memory card is no longer recognized, what can I do?
The following symptoms may indicate that a storage medium is faulty:
If your memory card has any of these symptoms it needs to be repaired or replaced. But before that you should try the following:
If the memory card has a small slide switch on the side of it (write protection), please change it and check if the problem persists. Furthermore you should check the card on another device to see if you have the same issues, this ensures that there is no fault with the device. Dirt should also be removed if any. You can do this by cleaning the contacts of the card, e.g. Carefully clean with a cotton bud soaked in spirit.
Many operating systems even offer special repair functions for storage media. Under Windows right-click on the faulty memory card and select properties then select Tools and now “run error checking”, e.g.. With the Mac, programs such as Recovery Wizard and on smartphones special data rescue apps (usually require root access) will help.
Review Date: 2021-10-01
