46102members
5476online
158119posts
This video describes step by step how you can reset the system to its factory settings: Reset Windows device to factory settings
WIN + E, double-click on C:, and open the Users folder. You will now find an overview of all user accounts that have been created on this Windows system. Open these and look in each folder to see if there is anything to back up. right-click on Start (the Windows flag) and select Installed Apps from the menu that appears.Procedure: Press the
Windows key, type cmd or Command Prompt, right-click on the result, and select Run as administrator. Confirm the following prompt with Yes. Now enter slmgr -ato in the window that appears and confirm with the Enter key. Once Windows has been activated, a pop-up message will display the status.The program is primarily used to restore the factory settings, and we have published a short video on YouTube explaining how to do this. This video explains everything you need to know. MEDION recommends using MEDION Recovery to restore the factory settings.
right-clicking on Start (the Windows flag) and selecting Settings.Delete, F8, or F12 key).Delete, F2, or F12 key repeatedly when starting the computer). Set the USB drive to the first boot position. If necessary, plug the USB stick into a USB 2 port (= not a blue port) and try again.The information in this article refers to:
ChangeLog:
Article in other languages:
Review Date: 2026-01-29
