46150members
612online
158119posts
F11 key continuously. On some notebooks, you must also hold down the Fn key.Shift key (above the Ctrl key) and click on Restart.Shift key (above the Ctrl key) and click on Restart.Windows key + R. In the Run window, enter the following command and confirm with Enter: shutdown /r /f /t 0 /oarrow keys. Resetting the device with an image you created: All personal files will be deleted.
Complete factory reset with backup: The user folder will be saved in C:\UserBackup.
ChangeLog:
Article in other languages:
Review Date: 2026-04-29
