Why does the connected microphone not work?
Check if the microphone is connected to the correct input.
If the microphone is connected to the correct input, remove it and reconnect it after a few seconds. Check if it is detected.
For a wireless microphone (e.g. Bluetooth microphone):
Check if the microphone is connected.
If the microphone is connected, disconnect and reconnect it.
Tip for devices with a Windows operating system:
For devices equipped with the Windows operating system, Windows offers its own troubleshooting that can help you immediately.
You can find out how to start troubleshooting in this FAQ: "How can I solve sound problems on Windows 10?"
Sometimes it is sufficient to renew or update the driver so that everything works again.
This also applies to microphones connected via USB or integrated in another device (e.g. webcam).
Changes can be made in the device manager.
Instructions can be found in this FAQ: "How do I update device drivers?"
Review Date: 2021-01-16
