The volume is too low or no sound at all, what can I do?
If you have no sound or the volume is too low from the connected speakers or headphones, please check if the volume on your device is set to minimum or mute and adjust it accordingly to meet your requirements.
If external headphones or speakers are connected remove them, reconnect them after a few seconds and check if they are now working.
For Bluetooth devices, disconnect and pair them again.
If there is still no sound, check if the connected headphone or speaker have their own volume control check they are not on low or mute.
Try another set of headphones or speakers and see if this resolves the issue.
Otherwise, follow the instructions in the volume guide and repeat the setup if necessary.
Review Date: 2020-06-01
