Question
How can I display the original installation date of my Windows operating system?
Answer
There are two ways to display the installation date:
Option 1:
- Open the settings on your device.
- Then select System.
- Now click on About and under the Windows specifications you can see the installation date of the Windows operating system.
Option 2:
- Enter CMD in the start search and open it / Alternatively, you can open the Run window with the key combination
Windows + R and enter CMD and open it.
- Now enter systeminfo and confirm the entry with
Enter.
- The entire system information opens and under Original Install Date the installation date of your Windows operating system is displayed.
