latest bios for medion earzer specialist p10 MSN30033735.
31 REPLIES 31
loukaspsomas
Message 1 of 32
Message 1 of 32
i want to update my bios.
medion erazer specialist p10 MSN30033735.
divice manager doesnt do the job to update bios.
i have the version 1.07.04RME1 8/9/22
what is the latest bios version? i cant find nowhere.
Tags (1)
31 REPLIES 31
Message 11 of 32
Message 11 of 32
Hello @Igor28
Thank you very much for the reply.
Unfortunately, this raises a few questions.
Why is the download for version 1.07.09RME1 listed with "Specialist P10" in the name when it's not actually for that model?
In this post: https://community.medion.com/t5/ERAZER-Gaming-NBs/ERAZER-SPECIALIST-P10-MD62434-DE-Fragen-zu-BIOS-US...
the download is linked for a Specialist P10 (62434=NP60PNP), and in post 11, it's shown as successful. How can that be if it's the wrong one?
To make matters even more confusing: There are two identical downloads with different sizes (00_Bios_Specialist_P10.zip): version 04 and version 09.
https://community.medion.com/t5/ERAZER-Gaming/Latest-BIOS-for-Erazor-Specialist-P10/m-p/151638#M2815
Version  04 (18,3MB): https://cdn.medion.com/downloads/software/00_Bios_Specialist_P10_.zip
Version 09 (56,9MB): https://cdn.medion.com/downloads/software/00_Bios_Specialist_P10.zip
bye Fishtown
Message 12 of 32
Message 12 of 32
@Igor28
Das ist alles ein wenig verwirrend, sogar widersprüchlich,  denn  das Bios
" 00_Bios_Specialist_P10.zip " (nach Entpacken 1.07.09RME1) wird im von Fishtown verlinkten Download so benannt:
--> d:\...\00_Bios_Specialist_P10.zip \ BIOS \ NPx0PNx.09RME1
Sollte also zum  Board
--> for Clevo PNP models like ERAZER Deputy P30, Specialist P10
doch passen?
Denn wenn man die " x'e " ersetzt?
Gruß daddle
Edit:
Sehe gerade Fishtown hatte gerade parallel geposted.
Message 13 of 32
Message 13 of 32
@Fishtown
Vergleicht man die Inhalte sieht du dass die Version 09 eine allumfassende Installationsmöglichkeiten bietet, mit der ME  und der kompletten .bin.
Es hat die 3 Verzeichnisse
ALL\
BIOS\
FF\
Aber letztlich gleichlautend von den Bezeichnungen der FW her gleich, bis auf die Versionsangabe. Hier irrt sich @Igor28  wohl.
Bye, daddle
Mastermind
Message 14 of 32
Message 14 of 32
Howdy,
if I may step in , I provided the info to @Igor28, because I knew, that  PNJ/PNK/PNH on the one hand & PNP on the other were using identical drivers, but referring to my knowledge operating with different graphic chips.
So I came to the conclusion that it would be better to take two diffenrent Bios versions, but as I now read my own conversations from 2024 the 1.07.09RME1 might also be suitable for the PNP series (even if the temperatures could not be effectively decreased.
Cheers
Message 15 of 32
Message 15 of 32
Hello @Major_ToM
Thank you very much for the confirmation
that means @loukaspsomas could install version 09.
bye Fishtown
loukaspsomas
Message 16 of 32
Message 16 of 32
i try to install 9 version but it says that bios is not for my system
Message 17 of 32
Message 17 of 32
@loukaspsomas
Which way did you try?
Did you decompress the zip first in a new folder??? And then did you do an   Windows Install with the  FlashWinX64.bat as an admin?
\ALL
\BIOS  the FlashMEWinX64.bat in this folder=
\FF
Edit:
You could take the inf install from the FF folder instead;  therein  the NP5XPNX.BIN is  mentioned as  NP5XPNX.BIN  to be flashed
Make a right click on the FF, and choose inf install from the context menu.
So steht es in der FF.inf
[SourceDisksFiles]
NP5XPNX.BIN = 1
[DestinationDirs]
DefaultDestDir = %DIRID_WINDOWS%,Firmware ; windows\Firmware
[Strings]
; localizable
Provider = "Clevo Corp."
MfgName = "Clevo Corp."
FirmwareDesc = "1.07.09RME1"
DiskName = "Firmware Update"
If that isn't possible, press Win tab + X  --> Device Manager -->  Systemfirmware -->  guide to the decompressed folder C:\00_Bios_Specialist_P10.zip \ FF\
and let Windows do the job.
@Major_ToM
The difference lies in the two FlashWinX64.bat in the folder Bios
Version 09 sets Bios name to NPx0PNx;   in contrary
Version 04 sets Bios name to NP5xPNP.
There are two bin files in the V. 09 download.
NP5xPNP.bin  (18590 k)     and
NPx0PNx .09RME1  (32768 k)
But in the FlashWinX64.bat only the  NPx0PNx.09RME1 is called.
So my question is, couldn't we just exchange in the V. 04 download  the  V 04  NP5xPNP.  bin  with the  newer  V.09  NP5xPNP.  bin ?
Or ist the NP5XPNP04.exe in the  V 04 DL a limitating factor?
Bye, daddle
loukaspsomas
Message 18 of 32
Message 18 of 32
i try, and with the divice manager  with the ff file and with the install  thing in bios folder. nothing working
Message 19 of 32
Message 19 of 32
@loukaspsomas
Is it still saying this Bios is not suitable for your PC, or are there  other reasons.
loukaspsomas
Message 20 of 32
Message 20 of 32
Help!
Now the laptop is not turn on after shut down windows!!!
Usb,s looks working they have power i mean! I unplug it i plug it again i try some things that i find to the internet i push the power button from 20 to 60 seconds and nothing. It looks like dead.
How i contact with support from medion to send the laptop to the technicians?????
31 REPLIES 31
