latest bios for medion earzer specialist p10 MSN30033735.
5 REPLIES 5
loukaspsomas
Message 1 of 6
Message 1 of 6
i want to update my bios.
medion erazer specialist p10 MSN30033735.
divice manager doesnt do the job to update bios.
i have the version 1.07.04RME1 8/9/22
what is the latest bios version? i cant find nowhere.
Tags (1)
1 ACCEPTED SOLUTION
Igor28
Message 6 of 6
Message 6 of 6
Hi @loukaspsomas ,
We inform you that the BIOS version 1.07.04RME1 is still the recent version.
Regarding to the issue, It could be the CPU cooling paste (depending to the intensity of usage) which may have “disappeared” in the meantime and has to be replaced with a fresh one.
Kind regards
5 REPLIES 5
Igor28
Message 2 of 6
Message 2 of 6
Hi @loukaspsomas ,
Could you please inform us why you want to update the BIOS?
Kind regards
loukaspsomas
Message 3 of 6
Message 3 of 6
Temperature of cpu is very high.  100c in gaming mode and normal mode 92.
I must to disable intel turbo boost  in windows to got normal temp. I have windows 11
Also when i disable that option im loosing 2ghz. From 4,6ghz i got 2,xxghz.
Just wanna try new bios. Maybe is fix any of my problem, also maybe is more settings in bioe because in the version of bios that i have is limited the settings.
Thank you
Igor28
Message 4 of 6
Message 4 of 6
Hi @loukaspsomas ,
I have requested a BIOS update from our technical support team. I will respond as soon as I receive feedback.
Kind regards
loukaspsomas
Message 5 of 6
Message 5 of 6
Thanks.
Igor28
Message 6 of 6
Message 6 of 6
Hi @loukaspsomas ,
Kind regards
5 REPLIES 5
