MD 63810 Tablet mode
31 ANTWOORDEN 31
Scoobyfizz
Bericht 1 van 32
27.391 Weergaven
Bericht 1 van 32
27.391 Weergaven
Hi,
I have just bought one of these new from Aldi. One of the things I bought it for was the fact that it hinged into a tablet, or at least shout.
When I flip it nothing happens , the screen rotates as it should but it does not go into tablet mode and the keyboard and mouse still are working. I thought that fliping the screen, according to the instructions would put it in tablet mode and would also sensibly lock the keyboard and track mouse to stop it working when in this mode. I have searched everywhere in windows to sort this out but nothing.
I have looked at the settings in tablet mode which are set as -
sign in - use the appropriate mode for my hardware
and when I use device as a tablet - always switch to tablet mode.
I have also performed a reset to no avail.. I suspect it is probably somewhere down the line something to do with the latest version of windows 10 which windows update did...
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Scoobyfizz
Bericht 31 van 32
11.384 Weergaven
Bericht 31 van 32
11.384 Weergaven
@daddle @Gehringer
Just to let you know the first unit I had must have had a faulty hinge sensor out of the box. I have just formatted and installed windows 10 from scratch and it seems to work fine without the drivers. Although I have now installed them just in case.
So all good and up to date with the latest version of windows and working tablet mode!!!
31 ANTWOORDEN 31
Gehringer
Retired
Bericht 2 van 32
9.242 Weergaven
Bericht 2 van 32
9.242 Weergaven
Hi @Scoobyfizz ,
please try option #3 listed on this link here
Regards,
Gehringer
Scoobyfizz
Bericht 3 van 32
9.236 Weergaven
Bericht 3 van 32
9.236 Weergaven
The latest build of windows does not have the options that are shown in that link you have sent.
settings has a tablet sub menu with only two options. When I sign in and when I use this device as a table with a menu underneath for change additional tablet settings. the Make Windows more touch-friendly when using your device as a tablet does not exist on the latest build 21H1
Scoobyfizz
Bericht 4 van 32
9.186 Weergaven
Bericht 4 van 32
9.186 Weergaven
I presume nobody has any advice. are there any other users of this device on here that this actually works for?
Scoobyfizz
Bericht 5 van 32
9.173 Weergaven
Bericht 5 van 32
9.173 Weergaven
is there any wat to check the functionality of the hinge. I may have to face the fact that it does not work from new?
Gehringer
Retired
Bericht 6 van 32
9.170 Weergaven
Bericht 6 van 32
9.170 Weergaven
Hi @Scoobyfizz ,
there is one last thing you can try which is the factory settings reset.
If it does not work, then I would advise you to contact the local Medion technical support team to have it assessed by a technician.
Regards,
Gehringer
Scoobyfizz
Bericht 7 van 32
9.160 Weergaven
Bericht 7 van 32
9.160 Weergaven
would a factory reset work given I have installed a fresh copy of windows 10....
Gehringer
Retired
Bericht 8 van 32
9.149 Weergaven
Bericht 8 van 32
9.149 Weergaven
Hi @Scoobyfizz ,
Have you updated this fresh copy to the version 21H1?
Regards,
Gehringer
Scoobyfizz
Bericht 9 van 32
9.145 Weergaven
Bericht 9 van 32
9.145 Weergaven
@Gehringer
yes fresh version of 21H1
Gehringer
Retired
Bericht 10 van 32
9.139 Weergaven
Bericht 10 van 32
9.139 Weergaven
@Scoobyfizz ,
so there is a chance your imaging file will be on a previous Windows version, which should give you access to the menus that are missing from yours.
Regards,
Gehringer
31 ANTWOORDEN 31
