MD 63810 Tablet mode
31 ANTWORTEN 31
Scoobyfizz
Nachricht 1 von 32
27.336 Aufrufe
Nachricht 1 von 32
27.336 Aufrufe
Hi,
I have just bought one of these new from Aldi. One of the things I bought it for was the fact that it hinged into a tablet, or at least shout.
When I flip it nothing happens , the screen rotates as it should but it does not go into tablet mode and the keyboard and mouse still are working. I thought that fliping the screen, according to the instructions would put it in tablet mode and would also sensibly lock the keyboard and track mouse to stop it working when in this mode. I have searched everywhere in windows to sort this out but nothing.
I have looked at the settings in tablet mode which are set as -
sign in - use the appropriate mode for my hardware
and when I use device as a tablet - always switch to tablet mode.
I have also performed a reset to no avail.. I suspect it is probably somewhere down the line something to do with the latest version of windows 10 which windows update did...
Scoobyfizz
Nachricht 31 von 32
11.356 Aufrufe
Nachricht 31 von 32
11.356 Aufrufe
@daddle @Gehringer
Just to let you know the first unit I had must have had a faulty hinge sensor out of the box. I have just formatted and installed windows 10 from scratch and it seems to work fine without the drivers. Although I have now installed them just in case.
So all good and up to date with the latest version of windows and working tablet mode!!!
31 ANTWORTEN 31
Gehringer
Retired
Nachricht 2 von 32
9.217 Aufrufe
Nachricht 2 von 32
9.217 Aufrufe
Hi @Scoobyfizz ,
please try option #3 listed on this link here
Regards,
Gehringer
Scoobyfizz
Nachricht 3 von 32
9.211 Aufrufe
Nachricht 3 von 32
9.211 Aufrufe
The latest build of windows does not have the options that are shown in that link you have sent.
settings has a tablet sub menu with only two options. When I sign in and when I use this device as a table with a menu underneath for change additional tablet settings. the Make Windows more touch-friendly when using your device as a tablet does not exist on the latest build 21H1
Scoobyfizz
Nachricht 4 von 32
9.161 Aufrufe
Nachricht 4 von 32
9.161 Aufrufe
I presume nobody has any advice. are there any other users of this device on here that this actually works for?
Scoobyfizz
Nachricht 5 von 32
9.148 Aufrufe
Nachricht 5 von 32
9.148 Aufrufe
is there any wat to check the functionality of the hinge. I may have to face the fact that it does not work from new?
Gehringer
Retired
Nachricht 6 von 32
9.145 Aufrufe
Nachricht 6 von 32
9.145 Aufrufe
Hi @Scoobyfizz ,
there is one last thing you can try which is the factory settings reset.
If it does not work, then I would advise you to contact the local Medion technical support team to have it assessed by a technician.
Regards,
Gehringer
Scoobyfizz
Nachricht 7 von 32
9.135 Aufrufe
Nachricht 7 von 32
9.135 Aufrufe
would a factory reset work given I have installed a fresh copy of windows 10....
Gehringer
Retired
Nachricht 8 von 32
9.124 Aufrufe
Nachricht 8 von 32
9.124 Aufrufe
Hi @Scoobyfizz ,
Have you updated this fresh copy to the version 21H1?
Regards,
Gehringer
Scoobyfizz
Nachricht 9 von 32
9.120 Aufrufe
Nachricht 9 von 32
9.120 Aufrufe
@Gehringer
yes fresh version of 21H1
Gehringer
Retired
Nachricht 10 von 32
9.114 Aufrufe
Nachricht 10 von 32
9.114 Aufrufe
@Scoobyfizz ,
so there is a chance your imaging file will be on a previous Windows version, which should give you access to the menus that are missing from yours.
Regards,
Gehringer
31 ANTWORTEN 31
