Why does the operating system not start?
Question
Answer
If your device can be switched on but the operating system does not start, there is usually a software error:
  • If the settings in the BIOS have been changed, the correct boot sequence must be set so that the system starts properly.
  • If your system can still be started, load the last restore point and reset your system to a working state. You can access this directly via the search bar by entering the word: restore point.
  • Restoring the delivery state helps to correct any software problems. To do this, reinstall the operating system and perform all updates.
Version history
Last update:
‎22.04.2024 06:02
Updated by:
Contributors
