This website uses Cookies. Click Accept to agree to our website's cookie use as described in our Privacy Policy. Click Preferences to customise your cookie settings.
Why is the touchpad of my laptop without function?
Answer
The touchpad of a laptop, which is used to move and control the Cursor, may be disabled. Activate the touchpad via the corresponding key combination with FN + corresponding key. You can find the correct key in the manual of your device. Alternatively, you can find a corresponding symbol on one of the Function keys of your notebook keyboard.
The driver of your touchpad may have been damaged by an update or a faulty installation. Here you can learn everything about device drivers under Windows.
A test can determine whether the error is software-related or hardware-related. Test the hardware with alternative software. Temporarily boot a fresh Windows, Linux, or Unix from a USB flash drive to cross-test the operation of the touchpad on a different operating system.
Loading the delivery state can also solve the error.
