46154members
935online
158119posts
What do the error codes mean for the MD 18600 Robot Vacuum Cleaner?
Please refer to the following table for error codes and solutions:
| Error code | Meaning | Solution |
| E01 | Left wheel is blocked. | Remedy the fault on the wheels. |
| E02 | Right wheel is blocked. | Remedy the fault on the wheels. |
| E05 | Sensor fault | Move the robot vacuum cleaner to a brighter place. Clean the sensor. |
| E06 | Appliance is blocked. | Move the robot vacuum cleaner to a different place. |
| E08 | The side brushes do not move. | Remove the brushes, clean them thoroughly and then reattach. After replacing the side brushes, check that the drive shaft does not slip.1 |
| E10 | On / Off switch is set to 0. The battery block is flat. |
Set the On / Off switch to I. Leave the battery block to charge fully for approx. 4.5 hours. |
1To check whether it is possibly due to the replaced brushes, please mount the previous brushes and check the function again.
If possible, only use original accessories
You can also find further support here:
Manual Robot Vacuum Cleaner MD 18600 (de, es, fr, nl, it)
Video Tutorial: Probleme mit Deinem Saugroboter? (German language)
If the solutions given are not successful, please contact our support.
ChangeLog:
Article in other languages:
Review Date: 2025-10-01
