Medion Akoya s2217 MD99525 video driver
10 ANTWORTEN 10
GabrielMC
Nachricht 1 von 11
10.730 Aufrufe
Nachricht 1 von 11
10.730 Aufrufe
I recently installed windows 10 2004 version and dont recognize the video driver . Where I can find the video driver for that windows version ? Or what windows version I need install for its better performance , I need help fast please. 🙏
Tags (2)
10 ANTWORTEN 10
Gehringer
Retired
Nachricht 2 von 11
9.295 Aufrufe
Nachricht 2 von 11
9.295 Aufrufe
Hi @GabrielMC ,
if you have Windows 10 you can upload the driver directly from the device manager.
Alternatively, you can check for drivers at video card manufacturer website.
Please find more information on this post here
Regards,
Gehringer
Luke
Community Manager
Nachricht 3 von 11
9.292 Aufrufe
Nachricht 3 von 11
9.292 Aufrufe
Hello @GabrielMC & @Gehringer,
The GPU is an Intel HD Graphics, a driver-tool can be found at their website.
Cheers,
Luke
GabrielMC
Nachricht 4 von 11
9.274 Aufrufe
Nachricht 4 von 11
9.274 Aufrufe
Sorry , it doesn't work , it's says : not supported driver or software updates are available for your system . @Luke @Gehringer
GabrielMC
Nachricht 5 von 11
9.270 Aufrufe
Nachricht 5 von 11
9.270 Aufrufe
This is how looks like
GabrielMC
Nachricht 6 von 11
9.266 Aufrufe
Nachricht 6 von 11
9.266 Aufrufe
I try everything and it doesn't work and is not only video , same as audio , I can't use my hdmi port. Can u send me a good driver for mail , whatsapp , mega . The msn is 30019439
Luke
Community Manager
Nachricht 7 von 11
9.217 Aufrufe
Nachricht 7 von 11
9.217 Aufrufe
Hello @GabrielMC,
That`s indeed strange.
Please go to Device Manager -> Audio/Video & Graphics Adapters and expand the relevant sections. Then check if there is a listed driver or not.
Right click on each driver listed and select the "update driver" option.
Please keep us informed,
Luke
GabrielMC
Nachricht 8 von 11
9.138 Aufrufe
Nachricht 8 von 11
9.138 Aufrufe
It doesn't work , the controller's doesn't found the video driver , I don't know how to fix , it's any place where I can found the originals drivers ???
Nachricht 9 von 11
9.126 Aufrufe
Nachricht 9 von 11
9.126 Aufrufe
Hi @GabrielMC ,
I hope it helps:
http://www1.medion.de/downloads/?op=search&lang=uk&type=TEXT&param=s221x&imageField.x=0&imageField.y...
bye Fishtown
CarlosVal
Visitor
Nachricht 10 von 11
9.108 Aufrufe
Nachricht 10 von 11
9.108 Aufrufe
Hello,
I have uploaded original drivers. Try "chipset" and "win8" instaler. Then "sound" "win8" "PG033" "setup.exe" and reboot,
xxxxxxxxxxxxxxxxxx
Hope it helps,
Carlos
EDIT:
External links removed due to possible violation of our Terms of Use,
points 6.2, 6.3, 6.4, 6.7 & 13.
10 ANTWORTEN 10
