on 05.10.2020 18:53
on 05.10.2020 18:53
I recently installed windows 10 2004 version and dont recognize the video driver . Where I can find the video driver for that windows version ? Or what windows version I need install for its better performance , I need help fast please. 🙏
on 06.10.2020 11:18
on 06.10.2020 11:18
Hi @GabrielMC ,
if you have Windows 10 you can upload the driver directly from the device manager.
Alternatively, you can check for drivers at video card manufacturer website.
Please find more information on this post here
Regards,
Gehringer
06.10.2020 13:02 - edited 06.10.2020 13:06
Hello @GabrielMC & @Gehringer,
The GPU is an Intel HD Graphics, a driver-tool can be found at their website.
Cheers,
Luke
on 06.10.2020 16:15
on 06.10.2020 16:15
Sorry , it doesn't work , it's says : not supported driver or software updates are available for your system . @Luke @Gehringer
on 06.10.2020 16:18
on 06.10.2020 16:51
on 06.10.2020 16:51
I try everything and it doesn't work and is not only video , same as audio , I can't use my hdmi port. Can u send me a good driver for mail , whatsapp , mega . The msn is 30019439
on 07.10.2020 08:10
on 07.10.2020 08:10
Hello @GabrielMC,
That`s indeed strange.
Please go to Device Manager -> Audio/Video & Graphics Adapters and expand the relevant sections. Then check if there is a listed driver or not.
Right click on each driver listed and select the "update driver" option.
Please keep us informed,
Luke
on 12.10.2020 00:44
on 12.10.2020 00:44
It doesn't work , the controller's doesn't found the video driver , I don't know how to fix , it's any place where I can found the originals drivers ???
on 12.10.2020 07:55
on 12.10.2020 07:55
Hi @GabrielMC ,
I hope it helps:
bye Fishtown
on 12.10.2020 12:19 - last edited on 12.10.2020 15:20 by Gehringer
Hello,
I have uploaded original drivers. Try "chipset" and "win8" instaler. Then "sound" "win8" "PG033" "setup.exe" and reboot,
xxxxxxxxxxxxxxxxxx
Hope it helps,
Carlos
EDIT:
External links removed due to possible violation of our Terms of Use,
points 6.2, 6.3, 6.4, 6.7 & 13.
