Medion Akoya E14410
20 REPLIES 20
deyu23
Message 1 of 21
Message 1 of 21
Medion Akoya E14410
I want to upgrade ssd (i just have 128gb) and ram memory.
Just checked with a few programs (CPU Z) and show the laptop have 2 slots for ram, one slots are occupated with 4gb and one free.
I want to know, what type of ssd are compatible and where are the ram (both slots located
Thnak you
20 REPLIES 20
deyu23
Message 11 of 21
Message 11 of 21
Just 256 GB its the maxim supported ? Why just that 😞
Message 12 of 21
Message 12 of 21
@Andi
Hallo Andi, HappyNew Year.
Danke für die Bestätigung meiner Angaben in Post 2. Mir glaubte @deyu23 wohl nicht.
@daddle   schrieb:
 @deyu23
Sorry, but your E14410  only has one ram slot; equipped with 4 GB. Maximum the database says is 32 GB.
-->   1x 4096 MB DDR4 SO-DIMM (PC4-21300 / 2666 MHz) (1/1 covered; 32 GB max.)
Wichtig ist die Ergänzung der Begrenzung auf 256 GB für die SSD. Aber ist  es vielleicht so, wie bei manchen anderen Modellen auch, dass nur die 256 GB getestet sind, aber über Try und Error zeigen könnte, dass auch eine 500 GB M2  funktioniert?
Message 13 of 21
Message 13 of 21
Hi @deyu23
the probability is high that you have 512GB can naue. you have a:
MEDION AKOYA E14410 (MD 63800)
BB JP E14410 SF40IL6 MD gr/bk w LTE
the sister model is almost identical and has the same board and cpu but SSD M.2 512GB SATA
MEDION AKOYA E14409 (MD 62331)
BB JP E14409 SF40IL6 MD gr/bk w/o LTE
  • SSD (M.2) (2280) Sata; 512 GB
order the 512GB, what happens in the worst case? you have to exchange them 😎
bye Fishtown
kommodore_ss
Message 14 of 21
Message 14 of 21
Guys , how you managed to open the back case? i struggle a lot and can't open the part near the screen
deyu23
Message 15 of 21
Message 15 of 21
You also have screws on the legs of the laptop, peel them slowly with something sharp, then you can put them back without any worries
deyu23
Message 16 of 21
Message 16 of 21
kommodore_ss
Message 17 of 21
Message 17 of 21
Thank you, sadly the fan was very noisy and while trying to fix it , i completly broke the fan...any chance i can find a spare one?
Thank you!
Tags (1)
deyu23
Message 18 of 21
Message 18 of 21
That's right, you're right, the fan is very noisy and extremely small, at first I thought the laptop had a problem.
Unfortunately, I don't know you where to try to find a suitable fan.
kommodore_ss
Message 19 of 21
Message 19 of 21
Guess we need to search for a replacement... can you handle the noise?
deyu23
Message 20 of 21
Message 20 of 21
I got used to accepting the noise of fan.  But I can't adapt with the sound quality of the speakers. Nokia n95 sound better :)))
20 REPLIES 20
