Keyboard problem S4403
48 ANTWOORDEN 48
AndrewP
Bericht 1 van 49
51.800 Weergaven
Bericht 1 van 49
51.800 Weergaven
I have a problem with my keyboard and hope someone can help.
Recently I had an update to my VPN fail. The installer automatically rolled back the installation, but this did not complete correctly and, after rebooting twice I noticed various problems with my notebook. I have succeeded in resetting the icon spacing on the task bar and the line spacing in File browser, but I have a problem with the keyboard occasionally repeating characters as I type. Usually it only repeats one character but occasionally it will repeat the last two characters so that for example "the" comes out as "ththe". I know my typing is not perfect but this is much more frequent that before and I never repeated two characters like this.
I have tried changing the repeat key delay setting in Windows but it does ntoto help. [I left ntoto in as an example that just happened, I mistyped not as nto (a common mistake for me😁) but it came out as ntoto].
Does anyone have any ideas?
Thanks!
S4403 - MD 61325, Windows 10 Home v20H2, build 19042.804, Windows Feature Experience Pack 120.2212.551.0
2 GEACCEPTEERDE OPLOSSINGEN
Geaccepteerd Solutions
PathMan
Bericht 42 van 49
21.549 Weergaven
Bericht 42 van 49
21.549 Weergaven
Good Morning fellas!
An update from me! My issue with this was fixed on the 12th March, but reappeared this morning (26th March).
I went into Device Manager to look at the driver and it had updated to the latest version. However,  on this occasions I have the option to "Roll back" the driver (that option wasn't there previously). I clicked on this option and reported why I was rolling back (repeating letters when typing), and it rolled back to the previous version immediately!
I have re-booted and the problem is resolved
I don't know whether or not I will regularly have to keep doing the same?
Regards and thanks for all your help!
Herman-
Bericht 45 van 49
20.901 Weergaven
Bericht 45 van 49
20.901 Weergaven
Hi,
Similar problem here: double characters (also enter, space, backspace, tab, etc...) when typing.
Occurred after driver update "Intel(R) Corporation - HIDClass - 2.2.1.384" (HID Event Filter)
Problem solved after re-installing "previous driver version" (in my case 2.2.1.372)
For now, I am not going to try to install version 383, I will wait and see what Windows will do in upcoming updates.
Thanks to the Medion Community for pointing me in the right direction!
S4401 - MD61269 - Windows 10 20H2 build 19042.928 - Windows Feature Experience Pack 120.2212.551.0
48 ANTWOORDEN 48
Gehringer
Retired
Bericht 2 van 49
12.755 Weergaven
Bericht 2 van 49
12.755 Weergaven
Hi @AndrewP ,
have you tried to factory settings reset it?
If you are willing to do that, please remember to back up your data first and be sure you can recover and regain access to your apps and accounts.
Regards,
Gehringer
AndrewP
Bericht 3 van 49
12.753 Weergaven
Bericht 3 van 49
12.753 Weergaven
Hi @Gehringer,
I have not tried that, I was hoping for a less drastic solution. My data is safe (I back up over my home network) but restoring all the apps and accounts would take a lot of time.
If I don't find a simpler solution I may have to do this.
Thanks.
toryglen
Bericht 4 van 49
12.720 Weergaven
Bericht 4 van 49
12.720 Weergaven
I had an issue with the taskbar too.
The spacing between the icons was noticeable.
I did a system reset which solved that part.
But my other issue, was the typing.
Regardless where I typed, a word document, or online,
I keep getting repeated letters or characters.
I have a Medion Notebook (Laptop) S4402 MD63410. Windows 10 Home.
Bought August 2019, so still within the 3 year warranty
I contacted Microsoft. They asked me to connect and external keyboard
That seemed to work without issue.
I don't know if this is a Software or Hardware problem.
I changed the setting to reduce the repeat character function, but no joy.
Let me know if you get this resolved.
I will do like-wise.
In the meantime I trying to relay  this issue via Medion Services.
AndrewP
Bericht 5 van 49
12.715 Weergaven
Bericht 5 van 49
12.715 Weergaven
@toryglenI will let you know if I find any solution. We seem to have exactly the same problem.
Did you have problems with the line spacing in Windows file explorer?
toryglen
Bericht 6 van 49
12.695 Weergaven
Bericht 6 van 49
12.695 Weergaven
Yes.
When on thinking back I had that noticeable issue too.
As you say, opening a window which displayed the contents, the spacing was increased.
The only thing I did prior to all of this was download iTunes.
I have since deleted that, which makes no difference to my typing.
I have had a look at the "nuts and bolts" under keyboard devices:
I notice that there are two (drivers) with the same description.
I am hesitant of deleting one over the other.
(I'm guessing one may be interfering with the other, but that is just a guess)
They both register the same information, apart from their descriptions:
"on Converted Portable Device Control device"
"on Intel(R) HID event Filter"
I hope the screenshots show below.
I am every so tempted to uninstall then re-install.
But I am wary.
Bericht 7 van 49
12.688 Weergaven
Bericht 7 van 49
12.688 Weergaven
@toryglen
The problem is often related to wrong Version of the Hid Event Filter. It should be V. ...384 or newer.
regards, daddle
toryglen
Bericht 8 van 49
12.682 Weergaven
Bericht 8 van 49
12.682 Weergaven
Does this help resolve the typing issues?
If so:
Where and how do I download this "Hid Event Filter" version 384.
Bericht 9 van 49
12.681 Weergaven
Bericht 9 van 49
12.681 Weergaven
@toryglen
Here: ---> https://www.catalog.update.microsoft.com/Search.aspx?q=intel+hid+event+filter
You must actualize the page, and look for Version 2.2.1.384.
If it cures all your problems I can not say; but it doesn't harm either.
AndrewP
Bericht 10 van 49
12.678 Weergaven
Bericht 10 van 49
12.678 Weergaven
@toryglenthe problem with the line spacing and icon spacing is from the settings for the touch screen. Go to Settings, System then select Tablet on the left and Change additional tablet settings on the right. In the additional settings switch off the options under When I'm not using tablet mode. This worked for me.
I got this from a Microsoft forum thread.
48 ANTWOORDEN 48
