Add second hard disk to Medion Akoya 6445
3 REPLIES 3
suthzero
Message 1 of 4
Message 1 of 4
Hi,
is it possible to add a second drive to this laptop, using this empty space? (see photo)
I don't recognize the connector (marked with arrow)
Thanks.
3 REPLIES 3
Message 2 of 4
Message 2 of 4
@suthzero
Hi suthzero,
welcome here.There are models S 6445  with an additional HDD built in sold in 2018/19.
But the problem ist to get the flat ribbon cable for the connection. And I do not even know if comes with a plug readily mounted on the disks side.
I have made an inquiry at Medion service for this. But the answer will take about a week.
Please state the MSN number of your laptop here.
Cheers, daddle
suthzero
Message 3 of 4
Message 3 of 4
Hi daddle,
thanks for your kind reply.
My MSN number is 30025468
Message 4 of 4
Message 4 of 4
@suthzero
Your Number isn't listed in the spare part list. But just be patient, If I get an answer fpr my request, I will inform you.
Cheers, daddle
3 REPLIES 3
