My First Post
17 ANTWOORDEN 17
bigman1974
Bericht 1 van 18
15.355 Weergaven
Bericht 1 van 18
15.355 Weergaven
My First Post
Hello Everyone
I found it very difficult to penetrate the username/password section of the forum but I hope I'm in business now. I'm having problems with my Akoya laptop,
since I updated from Windows 7 to Windows 10, and Im hoping there's someone able to help. I will put all the details in my next post.
17 ANTWOORDEN 17
bigman1974
Bericht 11 van 18
6.757 Weergaven
Bericht 11 van 18
6.757 Weergaven
I will try the residual current discharge tomorrow.
I only have product keys for Windows 10 and 7 (the original OS), so to try 8.1 I would probably have to buy it? That's not very attractive, as I've no guarantee that it will work.
I'll let you know how I get on.
regards, Bigman1974
Bericht 12 van 18
6.752 Weergaven
Bericht 12 van 18
6.752 Weergaven
@bigman1974
May be you just use Media Creation Tool for downloading Win 8.1 Iso on a USB Stick (8GB), and install it. If you are asked for  a product key say later. If you are booted to Win 8.1, I think you can do the bios update without activating Windows. Just try it. With right click as an Admin, power supply connected,  for safety the charge should be not full 100%, power supply should be active and charging, battery around 75 %.
Good luck, daddle
Bericht 13 van 18
6.751 Weergaven
Bericht 13 van 18
6.751 Weergaven
@bigman1974
May be you just make use of the Media Creation Tool for downloading Win 8.1 Iso on a USB Stick (8GB), and install it. If you are asked for  a product key say later. If you are booted to Win 8.1, I think you can do the bios update without activating Windows. Just try it. With right click as an Admin, power supply connected,  for safety the charge should be not full 100%, power supply should be active and charging, battery around 75 %.
Good luck, daddle
bigman1974
Bericht 14 van 18
6.737 Weergaven
Bericht 14 van 18
6.737 Weergaven
Hi Daddle
I followed your instructions for the RC discharge, and I'm afraid that it didn't fix the problem. I will look into your suggestion about the MCT, which I don't know anything about, and I will get back to you.
regards, Bigman1974
Bericht 15 van 18
6.732 Weergaven
Bericht 15 van 18
6.732 Weergaven
@bigman1974
Here is the link:
--> https://answers.microsoft.com/en-us/windows/forum/windows_10-windows_install-winpc/how-to-download-o...
Downloadlink scrolling the page down. You need a min. 8GB USB-Stick.
Regards, daddle
bigman1974
Bericht 16 van 18
6.696 Weergaven
Bericht 16 van 18
6.696 Weergaven
Hello Daddle
I spent some time trying to decide whether to pursue this idea of using Windows 8.1 as a means of getting the BIOS update thats on the Medion website to work, and Ive decided against it. The balance of advice seems to be that its best not to attempt a bios update unless you are definitely going to get an improvement you need, or definitely resolve an issue that you have, because of the consequences of it going wrong.
I agree with you that the problem is something to do with configuration, and if I was able to update the bios, I think its very unlikely that it would resolve the issue.
My last strategy will be to attach a second monitor, and see what affect that has.
BB_404
Bericht 17 van 18
4.574 Weergaven
Bericht 17 van 18
4.574 Weergaven
Hello im thinking of buying an rtx 3060ti 3 fan edition. Will it fit in my B460H6-EM motherboard? @daddle @Gehringer @Fishtown
Bericht 18 van 18
4.568 Weergaven
Bericht 18 van 18
4.568 Weergaven
@BB_404
Hi!
You are in a complete wrong thread. Open up a new Thread with appropriate title  in the category your PC fits in: Discussion forum >>  Computer/Network >>  Desktop PC  and All in One
We do not know which PC you have, so first state the MSN number and the name of your PC as well.
Cheers  daddle
17 ANTWOORDEN 17
