I have a medion erazer recon e10 (MD35004) will a 3060ti 3 fans fit in my motherboard?
8 REPLIES 8
BB_404
Message 1 of 9
Message 1 of 9
1 ACCEPTED SOLUTION
Message 8 of 9
Message 8 of 9
@BB_404
I can not follow you.  I answered your question concerning the thread title. Even some more.
What abaout the MSN number? As long as you do not state this the answers might not be precise.
Check under msinfo32  the SKU entry. The eight digits at the end might be the MSN of your PC.
What is a slot for a fan???
There is a second slot for a PCIe  M.2 SSD.
Your booting device is a SATA M.2 SSD.
I would advise you to read a little bit in Internet. There are enough articles explaining the basics of computers.
The specs for your PC you can ask for here.
8 REPLIES 8
Message 2 of 9
Message 2 of 9
@BB_404
I did ask you to províde the MSN also!
Your picture I can't see yet. Only tomorrow.
No, your PSU ist to small; it only provides 250W and has no additional plugs for the graphic card.
What is the TDP of the Nvidia 3060 TI?
BB_404
Message 3 of 9
Message 3 of 9
I know that the psu is too weak thats why im getting a corsair CX650M too power the gpu. I dont know what the MSN is but the the TDP of the rtx 3060 ti is 200 watts. I have windows 11
Message 4 of 9
Message 4 of 9
@BB_404
I dont know what the MSN is.
So why don't you tell this first?
The MSN of our Laptop is on a sticker underneath.
And if you fit a new stronger PSU for a new  graphic card, why should the new card not be compatible with your mainboard?
BB_404
Message 5 of 9
Message 5 of 9
I thought that the gpu wouldnt fit in the motherboard. So the gpu will fit in the motherboard?
Message 6 of 9
Message 6 of 9
@BB_404
Then you should formulate your question more precisely.
And how do you mean that new question?
The MB is a normal micro ATX board with a PCIe x16 expansion slot.
BB_404
Message 7 of 9
Message 7 of 9
Okay my bad daddle for not asking my question more precisely. But is there any slots for ssd or for some fans? In the motherboard?
Message 8 of 9
Message 8 of 9
@BB_404
BB_404
Message 9 of 9
Message 9 of 9
I believe its 10024366
8 REPLIES 8
