46043members
3132online
158067posts
What do the error codes displayed by my camping air conditioner P502 (MD 37735) mean?
| Problem | Possible cause | Solution |
| FL (water tank full) | Water tank of the outdoor unit full. | Empty the water tank. |
| Check if the drainage pump is functioning correctly. | If the drainage pump is defective, contact MEDION-Service | |
| Check if the drain hose is pinched or kinked. | Lay the drain hose without bends. | |
| EO (Communication error between the main control board and the UI board) | Circuit board error. | Contact MEDION-Service, possibly board replacement necessary. |
| E1 (Room temperature sensor failure) | Sensor terminals not properly plugged in. | Contact MEDION-Service, possibly sensor replacement necessary. |
| E2 (System temperature sensor failure) | Sensor terminals not properly plugged in. | Contact MEDION-Service, possibly sensor replacement necessary. |
| EF (Indoor unit feedback error) | Indoor unit motor defect. | Contact MEDION-Service, possibly motor / board replacement necessary. |
| EA (Four-way valve error) | Check if the four-way valve plug is correctly inserted. | Contact MEDION-Service, possibly four-way valve replacement necessary. |
| EC (Compressor overheating protection activated) | Room temperature too high. | Room temperature exceeds 40°C. |
| Refrigerant circuit damaged. | Do not operate the device in case of a leak. Contact MEDION-Service. | |
| E4 (Ice formation) | Cooling or dehumidifying the device at low temperatures. | The E4 code displayed during cooling at low temperatures is normal and can be automatically reset. |
| Check if the cold air outlet is blocked. | Ensure even air flow. |
ChangeLog:
Article in other languages:
Review Date: 2025-10-03
