FAQ: Specifications Mainboard "Asus PRIME A320I-K".
FAQs about the mainboard Asus PRIME A320I-K
MSN 20067819
  • Which processors (CPUs) can be used?
  • AMD Ryzen first Generation
    AMD Ryzen second Generation
    AMD Ryzen with Radeon Vega GPU
    AMD Athlon with Radeon Vega GPU
    AMD 7. Generation A-Serie
    AMD Athlon X4 CPUs
  • What is the maximum amount of working memory(RAM) that can be installed?
  • There are 4 memory slots on the mainboard each with 32 GB RAM. The maximum capacity is therefore 128 GB.
    Module: 288-Pin DIMM
    Type: SDRAM DDR4
    Speed: AMD Ryzen second Generation
      3600 (OC), 3466 (OC), 3400 (OC), 3200 (OC), 3000 (OC), 2933 (OC), 2800 (OC), 2666, 2400, 2133 MHz
    Speed: AMD Ryzen with Radeon Vega GPU / AMD Ryzen first Generation
    Speed: AMD 7. Generation A-Serie / AMD Athlon CPUs
      2400, 2133 MHz
    Voltage: 1.2 V
    Feature: no ECC-support
    ⚠️Note⚠️ In the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB of memory can be recognised. You can find more information on this on the Microsoft website.
  • Which M.2 cards can be used?
  • Slot Interface  Dimensions Key(s) Note
    1 SATA, PCIe 3.0 x4 1 2242, 2260, 2280 M key M.2 Combination cards with B and M key can be used
    1PCIe 3.0 x4 is supported by the following processors: AMD Ryzen second Generation / AMD Ryzen with Radeon Vega GPU / AMD Ryzen first Generation
    ⚠️Note⚠️ For the fastening you need a screw with a metric M2 thread and a length between 2.5 mm and 3.0 mm. The head should have a diameter of 4 mm to a maximum of 5 mm. If the screws are not available in local shops, you can find them in online shops.
  • What is the front pin assignment for the mainboard?
  • Overview of the onboard components
  • LAN Port LED Status
  • Assignment of the audio ports (rear)
Version history
Last update:
‎07.09.2023 13:19
Updated by:
Labels (2)
Contributors
