MSN 20065901
Intel CPUs of the 8 generation (Coffee Lake) and Pentium Gold / Celerons for the LGA 1151 socket
There are 2 memory slots on the mainboard each with 16 GB RAM. The maximum capacity is therefore 32 GB.
| Module: | 288-Pin Dimm |
| Type: | SDRAM DDR4 |
| Speed: | 2666/2400/2133 MHz |
| Voltage: | 1,2 V |
| Feature: | no ECC-support |
⚠️Note⚠️ In the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB of memory can be recognised. You can find more information on this on the Microsoft website.
| Slot | Interface | Dimensions | Key(s) | Hints |
| 1 | PCIe 3.0 x4 und SATA | 2260, 2280 | ||
| 2 | PCIe 3.0 x4 | 2260, 2280 | Optane ready |
⚠️Note⚠️ For the fastening you need a screw with a metric M2 thread and a length between 2.5 mm and 3.0 mm. The head should have a diameter of 4 mm to a maximum of 5 mm. If the screws are not available in local shops, you can find them in online shops.
The front pin assignment can be seen in the figure.
MSI provides the app Mystic Light, which can be downloaded from this link.
Article in other languages:
Review Date: 2025-03-06
