MSN 20062960, 20065365
Skylake and Kaby Lake CPUs bis 65 W TDP
There are 2 memory slots on the mainboard, each of which can hold 16 GB of RAM. The maximum capacity is therefore 32 GB..
| Module: | 288-Pin DIMM |
| Type: | SDRAM DDR4 |
| Clock: | 2400 MHz |
| Voltage: | 1,2 V |
| Special feature: | no ECC-support |
⚠️Note⚠️ In the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB of memory can be recognised. You can find more information on this on the Microsoft website.
| Slot | Connection | Dimensions | Key(s) | Comment |
| 1 | SATA | 2260, 2280 | M key | |
| 2 | PCIe x4 | 2260, 2280 | M key | optane ready |
| 3 | 2230 | E key | only WLAN |
⚠️Note⚠️ For the fastening you need a screw with a metric M2 thread and a length between 2.5 mm and 3.0 mm. The head should have a diameter of 4 mm to a maximum of 5 mm. If the screws are not available in local shops, you can find them in online shops.
The front PIN assignment can be taken from the illustration.
Article in other languages:
Review Date: 2025-03-05
