40687members
784online
141588posts
MSN 20066934
There are 4 memory slots on the mainboard each with 16 GB RAM. The maximum capacity is therefore 64 GB.
Module: | 288-Pin DIMM |
Type: | SDRAM DDR4 |
Clocking: | 4400(OC)/ 4300(OC)/ 4266(OC)/ 4200(OC)/ 4133(OC)/ 4000(OC)/ 3866(OC)/ 3733(OC)/ 3600(OC)/ 3466(OC)/ 3400(OC)/ 3333(OC) / 3300(OC) / 3200(OC) / 3000(OC) / 2800(OC) / 2666 / 2400 / 2133 MHz |
Voltage: | 1.2 V |
Feature: | no ECC-support |
⚠️Note⚠️ In the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB of memory can be recognised. You can find more information on this on the Microsoft website.
Slot | Interface | Dimensions | Key(s) | Hints |
1 | PCIe 3.0 x4, SATA 6Gb/s | 2242, 2260, 2280, 22110 | M key | Intel Optane Memory Ready |
2 | PCIe 3.0 x4, SATA 6Gb/s | 2280 | M key | Intel Optane Memory Ready |
3 | 2242 | E key | only WLAN |
SATA2 port will be unavailable when installing SATA M.2 SSD in M2_1 slot.
⚠️Note⚠️ For the fastening you need a screw with a metric M2 thread and a length between 2.5 mm and 3.0 mm. The head should have a diameter of 4 mm to a maximum of 5 mm. If the screws are not available in local shops, you can find them in online shops.
Article in other languages:
Review Date: 2025-03-06
