Camera not found error code "0xA00F4244"
15 REPLIES 15
BL19
Message 1 of 16
Message 1 of 16
Hello,
I recently bought Medion E15423- MD62545. My camera is not detected, I tried to troubleshoot everything right from checking on camera buttons to checking in device manager.
My problem is I cannot locate camera in device manager. Please can someone guide me to fix this issue?
15 REPLIES 15
Message 2 of 16
Message 2 of 16
@BL19
On the left side there is a private mode slider switch, switchíng the camera and internal microfon On/Off .
Cheers, daddle
BL19
Message 3 of 16
Message 3 of 16
Hello,
It is on. My microphone works fine it's just camera that doesn't.
Message 4 of 16
Message 4 of 16
@BL19
Dio you have the YouCam App installed?
Check with Microsoft:
https://support.microsoft.com/en-us/windows/camera-app-shows-error-0xa00f4244-nocamerasareattached-0...
Cheers, daddle
Mastermind
Message 5 of 16
Message 5 of 16
Hi @BL19 ,
could you please comment, if the issue with the cam is still present?
Cheers
BL19
Message 6 of 16
Message 6 of 16
BL19
Message 7 of 16
Message 7 of 16
Yes it is still the same issue.
Mastermind
Message 8 of 16
Message 8 of 16
Hi @BL19 ,
that sounds quite strange, but let´s see, how we can assist.
Generally this kind of error codes indicate, that there is a driver error (or a HW defect).
The thing is, that the driver is provided by Windows Inbox and not via providable driver files, so at first you might run the MEDION Service App,which tests the hardware features of the camera.
Of course you also could run a clean installation of the operating system via the Microsoft Media Creation Tool,but this would mean a lot of work.
Cheers
BL19
Message 9 of 16
Message 9 of 16
Hello @Major_ToM ,
I think the problem is with hardware. When I tried to press on the top of laptop screen near camera, it started working but after I close and open again there is same problem. I think there is some issue in the build-up.
Mastermind
Message 10 of 16
Message 10 of 16
Thanks@BL19 for the feedback.
You might try a clean installation before opening up a service case, to ensure, that we´re rteally talking about a hardware failure.
Cheers
15 REPLIES 15
