Erazer bandit p20 md3d34510 b660h7-m20 can't update bios
21 REPLIES 21
Mrdw
Message 1 of 22
Message 1 of 22
I just purchased the pc from currys and I can't see any way to update the bios for the motherboard. I can get in the bios but it looks like something from win95 and the only videos I can see on yt about this type of bios are from 13 years ago.
Has anyone else had the same issue and found a solution?
I've been in the device manager and tried to update firmware from there but no cigar.
21 REPLIES 21
RAZZ
Message 2 of 22
Message 2 of 22
Hi @Mrdw
are you able to provide the MSN (8 digits) of the unit and the current BIOS version, so we can look into this further.
Thanks
Mrdw
Message 3 of 22
Message 3 of 22
MSN: 10025150
Bios version B660H7WOX.206
On system info it says 1.0
Bios date: 01/12/23
RAZZ
Message 4 of 22
Message 4 of 22
Hi @Mrdw
Version 2.12 is currently under evaluation, but I can provide V 2.09: https://cdn.medion.com/downloads/software/00_Bios_b660h7-m20_v2.zip
-Unzip the file to a location on your SSD/HDD and execute the file WFH.bat by right clicking it and run it as admin
Important: MEDION AG accepts no liability whatsoever for any data loss or hardware or software errors that occur as a result of the update. The customer acknowledges this when performing the update.
thanks
Mrdw
Message 5 of 22
Message 5 of 22
Did exactly what you said, nothing happened.
Bios is still on same version.
RAZZ
Message 6 of 22
Message 6 of 22
Hi @Mrdw
Thanks for this update, I will look into this and get back to you
RAZZ
Message 7 of 22
Message 7 of 22
hi @Mrdw
please follow instruction from the video
https://cdn.medion.com/downloads/videos/IMG_4693_bios_ecs_b660h7.MP4
We suggest you start the console as Admin and execute the WFH.bat there. The VMD Settings generally are set as ‘Enabled’ by default after the BIOS.
This must be observed, otherwise a blue screen will appear.
thanks
Mrdw
Message 8 of 22
Message 8 of 22
I can't tell what was typed into cmd on this video..this will deffo update my bios right?
Vince
Message 9 of 22
Message 9 of 22
Mrdw
Message 10 of 22
Message 10 of 22
There no text in your reply
21 REPLIES 21
