BIOS Update for ERAZER X15807 (URGENTLY REQUIRED)
17 ANTWOORDEN 17
shakeeb_rao
Sleeper
Bericht 1 van 18
3.423 Weergaven
Bericht 1 van 18
3.423 Weergaven
Well, i have been noticing some power management issues with my keyboard for a very long time, some lights of keys of keyboard gets on whenever i plug in the laptop. But now, it has come to the situation that i cannot use my keyboard with the RGB lights on. Windows also do shows device descriptor Request failed for the port, means windows are disabling it due to improper behaviour from keyboard. Also, i cannot control my keyboard using control centre.
Secondly, it takes too much time to boot up and get to the home screen of windows. Whenever i press power button, for the 10 seconds, there is no response and after that, erazer logo shows up on laptop, which is clearly outdated BIOS. Kindly do help me.
Thanks.
laptop Details:
MD 61597
Erazer X15807
MSN 30027173
2 GEACCEPTEERDE OPLOSSINGEN
Geaccepteerd Solutions
RAZZ
Bericht 5 van 18
2.433 Weergaven
Bericht 5 van 18
2.433 Weergaven
Hi @shakeeb_rao
We have found V 1.53, which should be installed via Windows environment right click and “install” from the context menu.
https://cdn.medion.com/downloads/software/00_Bios_x17803_807_w1x.zip
thanks
Bericht 17 van 18
1.658 Weergaven
Bericht 17 van 18
1.658 Weergaven
Hi @shakeeb_rao
try that
https://cdn.medion.com/downloads/software/00_Bios_x17803_v152.zip
bye Fishtown
17 ANTWOORDEN 17
RAZZ
Bericht 2 van 18
2.501 Weergaven
Bericht 2 van 18
2.501 Weergaven
hi @shakeeb_rao
Do have the current BIOS version you are using so we can check if there are any updates.
thanks
shakeeb_rao
Sleeper
Bericht 3 van 18
2.498 Weergaven
Bericht 3 van 18
2.498 Weergaven
Firstly, Thanks for the reply,means alot to me.
BIOS manufacturer is American Megatrends Inc.
BIOS Version: N.1.52
BIOS Release Date: 04/10/2019
shakeeb_rao
Sleeper
Bericht 4 van 18
2.450 Weergaven
Bericht 4 van 18
2.450 Weergaven
Also, i do want to mention motherboard manufacturer model which is Medion GK5Cx.
Thanks.
RAZZ
Bericht 5 van 18
2.434 Weergaven
Bericht 5 van 18
2.434 Weergaven
Hi @shakeeb_rao
thanks
RAZZ
Bericht 6 van 18
2.431 Weergaven
Bericht 6 van 18
2.431 Weergaven
hi @shakeeb_rao ,
FYI
Medion do not advise doing a BIOS update unless the unit is bugging/crashing or you have changed hardware and the unit is not performing correctly. If it is working normally then no need to upgrade.
MEDION DISCLAIMER
we (Medion) do not accept any responsibility for damage or loss of data in case of any error, caused by the execution of updates to the BIOS and the unit
Thanks
shakeeb_rao
Sleeper
Bericht 7 van 18
1.017 Weergaven
Bericht 7 van 18
1.017 Weergaven
Hey, i successfully updated BIOS verison but unfortunately after using it for months, i have encountered several issues such as showing low battery light although laptop is fully charged. This issue persists when i try to turn on laptop on battery. Also, problems that i described earlier were not solved. Can you guide me about how can i revert back to the original version that i mentioned above, N.1.52
Just tell me how can i install it if i have to. Thanks
Bericht 8 van 18
1.002 Weergaven
Bericht 8 van 18
1.002 Weergaven
@shakeeb_rao
The battery symptoms rather show a worn out battery.
Windows says 100%;  even if the battery capacity is quite low already;  so even if the battery only has 40 rest capacity, as long as the battery provides the necessary voltage and current, and  charging is stopped due to  the the fact that the battery doesn't take more charge, Windows "thinks" the  battery is full.
But to know for sure, one has to hold and check the object physically.
Edit: Typo
shakeeb_rao
Sleeper
Bericht 9 van 18
977 Weergaven
Bericht 9 van 18
977 Weergaven
The point is everything regarding battery gets normal when i shut down my laptop and then turn it on plugged in. Only then it shows the correct charge of battery and i utilize the battery properly, gives me at least 2 hours backup. But i have been facing this issue since i updated bios. At first, this problem was not intriguing at all but now it is showing up every time i try to on the laptop.
shakeeb_rao
Sleeper
Bericht 10 van 18
931 Weergaven
Bericht 10 van 18
931 Weergaven
I will go on and make a visit to a professional to check the battery but can you share the link of Default BIOS version which is N.1.52 of the model mentioned above, I would be grateful
Thanks
17 ANTWOORDEN 17
