am 05.03.2021 17:15
am 05.03.2021 17:15
Hi all, think this notebook has only just been released (& arrived for many of us today in the UK) so thought I'd put a general discussions & queries thread for anyone wanting to follow along 😀
am 06.03.2021 11:17
am 06.03.2021 11:17
Hi @sHAYM4N and welcome,
Good idea, I'll start with general:
Operating instructions can be found here, spare parts are not yet available
https://www.medion.com/gb/service/topic/medion-products?msnCheck=30031013
Type:
NB BB Emdoor NS14AR E14304 titan grey
Dimensions / Weight:
Dimensions (W×H×D): ~ 324 × 22.5 × 220 mm
Weight: ~ 1.54 kg
CPU AMD Ryzen 3 4300U 2.7GHz / Chipset: SoC
hard disk:
SSD M.2 (2280) 256GB Phison PS3111-S11 B27 SATA /MSN 40072675
random access memory:
8x DDR4-2666 HYN 8Gb SDRAM H5AN8G6NCJR-VKC = 8 GB (onboard)
graphic:
AMD Radeon Vega Graphics:
Display:
14 " (35.5 cm) FHD 16:9 Color TFT-LCD (LED Backlight) Resolution: 1920 x 1080 Pixel (16:9) non Glare
Wlan:
WLAN Intel AC3165 SP AC+BT D2WG/ WLAN Standard: IEEE 802.11 ac, IEEE 802.11 a/b/g/n, Wi-Fi compliant
Host Interface: (PCIe, USB) * Frequency Range: 2.4GHz and 5.0GHz
connections:
1 x USB 2.0/ 1 x USB 3.2 Gen 1 Type-C (DisplayPort + charging)/
1 x HDMI/ 1 x 3.5 mm combo jack(microphone/headphone)/ Cardreader(micro SD/SDHC/SDXC)
battery pack:
BTY EMD NS1xIC/AR 456484-3S 45W/ MSN 40075218
Voltage (V): 3.85V * Capacity (Ah): 3896 mAh* 3 cells/ not changeable
power adapter:
PSUP Chicony A18-065N3A P2 3 Pin 65W/ MSN 40074990/
Rated Input Voltage: 100-240* Output Voltage: 18.55 - 19.95 / DC plug dimension is 3.5*1.35*11mm/ in = + / out = -
other:
HD webcam/ 2 speakers and 2 microphones
and before the first questions are asked, his wifi and the microphone is not working 😉
No.14 slide switch on the side:
“Private mode” slider switches the webcam and internal microphone on/off 15“Private Mode”
LED: lights up when the “Private Mode” is on.
bye Fishtown
am 06.03.2021 17:52
am 06.03.2021 17:52
Got this laptop a couple of days ago but finding the fan annoying, its not overly loud just has an annoying tone to it. Is there any software to either undervolt the CPU or make the fans kick in later as the temperatures are not really high when the fan kicks in.
Dont really want to return the laptop in the current climate as finding a replacement will be difficult
am 06.03.2021 20:56
am 06.03.2021 20:56
Never used it myself, but someone in the HUKD thread mentioned Notebook Fan Control - hope this helps!
am 06.03.2021 21:08
am 06.03.2021 21:08
would like to echo this comment from finners - gave my laptop to a family member who noticed this.
please medion release a bios update with better fan curves!
am 07.03.2021 13:09
am 07.03.2021 13:09
An updated bios with better fan curves would be ideal as toge suggested.
am 07.03.2021 14:21
am 07.03.2021 14:21
Wonder if there's quite a difference across the board as mine is really quiet. If the room is quiet and I am close to it I just about notice it, but otherwise it's incredibly quiet. My girlfriend cant stand noise from anything like this and she would definately be the first to complain (also why I cancelled a gaming laptop 😂) Would definately appreciate something with fan curves though. Doe the AMD present for gaming, standard power not make a difference then I presume?
am 09.03.2021 13:40
am 09.03.2021 13:40
Hi@sHAYM4N , @Finners , @toge ,
regarding the fan nois it would be helpful, to know your specific Bios & EC Biosversions, which are currently installed on your machines.
Maybe all of you could post a photo of your 1st BIOS screen, but please ensure that the serial number of your machine is not visible.
Just as further information, all images will have to be approved of the moderator staff, before they´re visible for all users.
Afterwards I´ll check if a current Bios/EC Bios is available
Cheers
am 09.03.2021 13:48
am 09.03.2021 20:30
Subject | Author | Posted | |
27.11.2021 17:51 | |||
19.04.2023 18:53 | |||
27.07.2024 16:19 | |||
21.02.2024 14:20 |
