Keyboard problem S4403
48 ANTWOORDEN 48
AndrewP
Bericht 1 van 49
51.319 Weergaven
Bericht 1 van 49
51.319 Weergaven
I have a problem with my keyboard and hope someone can help.
Recently I had an update to my VPN fail. The installer automatically rolled back the installation, but this did not complete correctly and, after rebooting twice I noticed various problems with my notebook. I have succeeded in resetting the icon spacing on the task bar and the line spacing in File browser, but I have a problem with the keyboard occasionally repeating characters as I type. Usually it only repeats one character but occasionally it will repeat the last two characters so that for example "the" comes out as "ththe". I know my typing is not perfect but this is much more frequent that before and I never repeated two characters like this.
I have tried changing the repeat key delay setting in Windows but it does ntoto help. [I left ntoto in as an example that just happened, I mistyped not as nto (a common mistake for me😁) but it came out as ntoto].
Does anyone have any ideas?
Thanks!
S4403 - MD 61325, Windows 10 Home v20H2, build 19042.804, Windows Feature Experience Pack 120.2212.551.0
48 ANTWOORDEN 48
toryglen
Bericht 11 van 49
9.972 Weergaven
Bericht 11 van 49
9.972 Weergaven
Thank you for that extra insight.
I'm still not having any luck with the typing issue.
I have inadvertly deleted one of the keyboard driver - needless to say this never solved anything.
AndrewP
Bericht 12 van 49
9.968 Weergaven
Bericht 12 van 49
9.968 Weergaven
@daddlethanks for the suggestion. I have found and downloaded version 2.2.1.384 but I am afraid I don't know how to install this. Can you please instruct me?
I can find two folders C:\Windows\System32\DriverStore\ hideventfilter.inf_amd64_xxxx.. containing the three files I just downloaded, but also containing another file with the extension .PNF that is not in the download. I note that the newer of these folders is dated 2021-02-01 which would coincide with when the problems started.
Thanks for the help.
Bericht 13 van 49
9.962 Weergaven
Bericht 13 van 49
9.962 Weergaven
@AndrewP
You have to install via the device manager --> Update driver
Or it reads the data from the cab file, or you first have to decompress it eg with 7zip.
AndrewP
Bericht 14 van 49
9.954 Weergaven
Bericht 14 van 49
9.954 Weergaven
@daddle @toryglen  When I try to update the driver it tells me that the latest driver is installed. I have now rolled back the driver to the previous version, 2.2.1.383, and so far this seems to be working. (No double letters in typing this reply!)
Thank you.
toryglen
Bericht 15 van 49
9.943 Weergaven
Bericht 15 van 49
9.943 Weergaven
Glad it has worked out for you.
I am still having issue.
Even tried an uninstall.
But no joy.
I don't have the option of roll back.
Looks like I will have to try a complete reinstall from scratch,
and re-install all my apps.
Long day ahead.
Thanks for keeping me informed
AndrewP
Bericht 16 van 49
9.937 Weergaven
Bericht 16 van 49
9.937 Weergaven
@toryglen  sorry to hear you still have problems. Perhaps you can download and install the 2.2.1.383 driver from the site daddle gave? If you click on Last Updated it is near the bottom of the first page.
toryglen
Bericht 17 van 49
9.933 Weergaven
Bericht 17 van 49
9.933 Weergaven
Unfortunately I’ve started from scratch. (Recovery USB)
If I encounter problems (hopefully not),
Thank you for helping me out.
I will come back when I am up and running again
toryglen
Bericht 18 van 49
9.904 Weergaven
Bericht 18 van 49
9.904 Weergaven
I am still having issues with this (double letter) typing.
I started from scratch, did a full recovery - now just a basic pc.
I tried installing 2.2.1.383 drive, to over ride 2.2.1.384,
The strange thing is the zip file may say 2.2.1.383,
but the actual driver version that is extracted is 1.1.1.318 (Intel(R) HID Event Filter)
Even with this, I am still double typing letters, even when I am precise with my typing.
it even occurs when I go the the command prompt!
is your laptop typing okay.
AndrewP
Bericht 19 van 49
9.894 Weergaven
Bericht 19 van 49
9.894 Weergaven
@toryglen
Mine is working normally now. I have not noticed any other problems.
When I go to device manager and check the driver version it shows 2.2.1.383, dated 2020-08-10.
toryglen
Bericht 20 van 49
9.888 Weergaven
Bericht 20 van 49
9.888 Weergaven
Thanks for replying
Can you tell where you downloaded from?
I tried two separate sites, claiming 2.2.1.383,
but when checked after unzipping, I’ve only got 1.1.1.318.
I appreciate any response, in advance.
48 ANTWOORDEN 48
