MSN 20069642
There are 4 memory slots on the mainboard, each of which can hold 32 GB of RAM. The maximum capacity is therefore 128 GB.
| Mit Intel Core 10th Generation i5/i3 /Pentium/Celeron | |
| Module: | 288 Pin-DIMM |
| Type: | SDRAM-DDR4 |
| Clock: | 2666/2400/2133 MHz |
| Voltage: | 1,2V |
| With Intel Core 10th Generation i9/i7 | |
| Clock: | 2933/2666/2400/2133 MHz |
| Voltage: | 1,2V |
| With Intel Core 11th Generation i9/i7/i5 | |
| Clock: | 3200 / 3000 / 2933 / 2800 / 2666 / 2400 / 2133 MHz |
| Voltage: | 1,2V |
⚠️Note⚠️ In the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB of memory can be recognised. You can find more information on this on the Microsoft website.
If you have not yet installed a memory, this video MSI-video may help you.
| Slot | Connection | Dimensions | Key(s) | Comment |
| 1 | PCIe 4.0 x4/x21 | 2260/2280 | M Key | |
| 2 | PCIe 3.0 x4/x2, SATA | 2260/2280/22110 | M Key | Intel Optane memory ready |
1Only supported by 11th generation processors.
⚠️Note⚠️ For the fastening you need a screw with a metric M2 thread and a length between 2.5 mm and 3.0 mm. The head should have a diameter of 4 mm to a maximum of 5 mm. If the screws are not available in local shops, you can find them in online shops.
The front PIN assignment can be taken from the illustration.
You can change the function of your audio jacks using the audio software.
1x PCIe 4.01 x16 slot (PCIEX16)2
1x PCIe 3.0 x16 slot (PCIEX4)
Supports the 2-Way AMD CrossFire Technology
1(The PCIEX16 slot complies with the PCI Express 4.0 standard.) Only supported by 11th generation processors.
2If you only need to install one PCI Express graphics card, you should install it in the PCIEX16 slot for optimal performance.
Article in other languages:
Review Date: 2025-03-05
