FAQ: Specifications Mainboard "ECS B250H4-EM".
FAQs about the Mainboard ECS B250H4-EM
MSN 20062960, 20065365
  • Which processors (CPUs) can be used?
  • Skylake and Kaby Lake CPUs bis 65 W TDP
  • What is the maximum amount of RAM that can be installed?
  • There are 2 memory slots on the mainboard, each of which can hold 16 GB of RAM. The maximum capacity is therefore 32 GB..
    Module: 288-Pin DIMM
    Type: SDRAM DDR4
    Clock: 2400 MHz
    Voltage: 1,2 V
    Special feature: no ECC-support
    ⚠️Note⚠️ In the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB of memory can be recognised. You can find more information on this on the Microsoft website.
  • Which M.2 cards can be used?
  • Slot  Connection      Dimensions         Key(s)           Comment
    1 SATA 2260, 2280 M key
    2 PCIe x4 2260, 2280 M key optane ready
    3   2230 E key only WLAN
    ⚠️Note⚠️ For the fastening you need a screw with a metric M2 thread and a length between 2.5 mm and 3.0 mm. The head should have a diameter of 4 mm to a maximum of 5 mm. If the screws are not available in local shops, you can find them in online shops.
  • What is the front PIN assignment for the mainboard?
  • The front PIN assignment can be taken from the illustration.
Version history
Last update:
‎07.09.2023 12:49
Updated by:
Labels (2)
Contributors
