Medion Erazer x20 reboots during gaming
6 REPLIES 6
AjayS
Message 1 of 7
Message 1 of 7
I've bought my Erazer x20 2 months ago during black friday, sometimes, not always, during gaming, the sound buzzes and the computer restarts itself. I read the posts about updating the bios, which I have done 2 weeks ago, the drivers are up to date & windows is up to date, but since then it still has crashed 3 times since then, twice the gpu must have not even been too loaded.
I can't find any other solution to the problem, but I would love to get a fix so I won't have to return it.
6 REPLIES 6
AjayS
Message 2 of 7
Message 2 of 7
Edit: Just now it rebooted and I wasn't even gaming, just chatting on discord.
Any suggestions on how to fix this? @JanD (Sorry for tag, I saw that you have been active in threads I found while searching for a solution). 🙂
AjayS
Message 3 of 7
Message 3 of 7
Oops- tagged the wrong person meant @Andi instead 🙂
Rookert
Message 4 of 7
Message 4 of 7
Are your fans still working?
AjayS
Message 5 of 7
Message 5 of 7
Yes, I can see the fans spin & there should be enough space around my computer for it to not overheat
Message 6 of 7
Message 6 of 7
Hi@AjayS & @Rookert ,
sorry for the late reply, but I´d like to know, if you alkready have the latest Bios version installed.
Pls also check this thread, because the problems have been solve by a new published Bios update
Cheers
AjayS
Message 7 of 7
Message 7 of 7
Hi Tom,
I send the pc back for repairation, the GPU was faulty and has been replaced, so far no overheating problems since, though it does sometimes restart when I wake it up from sleep
6 REPLIES 6
