on 08.01.2022 20:04
on 08.01.2022 20:04
I've bought my Erazer x20 2 months ago during black friday, sometimes, not always, during gaming, the sound buzzes and the computer restarts itself. I read the posts about updating the bios, which I have done 2 weeks ago, the drivers are up to date & windows is up to date, but since then it still has crashed 3 times since then, twice the gpu must have not even been too loaded.
I can't find any other solution to the problem, but I would love to get a fix so I won't have to return it.
on 09.01.2022 12:41
on 09.01.2022 13:51
on 12.01.2022 16:47
on 12.01.2022 18:54
on 12.01.2022 18:54
Yes, I can see the fans spin & there should be enough space around my computer for it to not overheat
on 03.02.2022 13:00
on 03.02.2022 13:00
sorry for the late reply, but I´d like to know, if you alkready have the latest Bios version installed.
Pls also check this thread, because the problems have been solve by a new published Bios update
Cheers
on 13.03.2022 03:16
on 13.03.2022 03:16
Hi Tom,
I send the pc back for repairation, the GPU was faulty and has been replaced, so far no overheating problems since, though it does sometimes restart when I wake it up from sleep
