Crawler E25 aka NH55EJQ-M buzzing right speaker
5 ANTWOORDEN 5
popus_czy_to_ty
Bericht 1 van 6
714 Weergaven
Bericht 1 van 6
714 Weergaven
My laptop is over 3 years right now so no warranty cover is included. Did somebody encounter this issue?
It started buzzing, before it happen i was plugging usb flashdrive on right side maybe that caused that. Where to search? What to replace? Schematics? Prices?
Heres example how it sounds:
https://youtu.be/Z2cS_hybSUQ
ps. i dont know how to describe that sound in English buzzing? overlimit? noise?
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Bericht 2 van 6
707 Weergaven
Bericht 2 van 6
707 Weergaven
Hello @popus_czy_to_ty
On the Medion Service Shop page, you can find the replacement part you're looking for by entering your MSN number: 30033639
https://www.medion.com/medionserviceshop/en/p/housing-medion-erazer-crawler-e25-md-62291-uk-30033639
There you'll find the right and left speakers you're looking for.:
https://www.medion.com/medionserviceshop/en/p/speaker-speaker-right-40072965
https://www.medion.com/medionserviceshop/en/p/speaker-speaker-left-40072961
If you'd like, I can also send you a service manual for the NH55EJQ for disassembly/opening purposes.
bye Fishtown
5 ANTWOORDEN 5
Bericht 2 van 6
708 Weergaven
Bericht 2 van 6
708 Weergaven
bye Fishtown
Bericht 3 van 6
683 Weergaven
Bericht 3 van 6
683 Weergaven
popus_czy_to_ty
Bericht 4 van 6
658 Weergaven
Bericht 4 van 6
658 Weergaven
discharge didnt help,yes you can send me service manual
@Fishtown your old link has expired [3rd party link removed
Admin Edit:
Please see our Terms of Use.
popus_czy_to_ty
Bericht 5 van 6
421 Weergaven
Bericht 5 van 6
421 Weergaven
i replaced speaker and problem has gone, however long time ago i didnt put all screws in box and im missing few screws does anyone knows sizes?
11, 10 should be M2,5x6L next 2, 7 M2,5x8L  and those two for keyboard lifting/holding what size should be? im correct?
Bericht 6 van 6
408 Weergaven
Bericht 6 van 6
408 Weergaven
that's correct
and the other two, if those are the ones you mean, are also listed there.
bye Fishtown
5 ANTWOORDEN 5
