45268members
1453online
156124posts
MSN 20067068
Processors from the Ryzen 3000 series can be installed.
There are 2 memory slots on the mainboard each with 16 GB RAM. The maximum capacity is therefore 32 GB.
| Module: | 288-Pin DIMM |
| Type: | SDRAM-DDR4 |
| Speed: | 2666 MHz |
| Voltage: | 1.2 V |
| Feature: | no ECC Support |
⚠️Note⚠️ In the 32-bit editions of Windows operating systems a maximum of about 3.2 GB memory is detected.You can find more information about this on the Microsoft website.
| Slot | Interface | Dimensions | Key(s) | Hints |
| 1 | PCIe oder SATA | 2260, 2280 | B key & M key | |
| 2 | 2230 | E key | WLAN only |
⚠️Note⚠️ The M.2 slot is covered by the graphics card. This must therefore first be removed in order to install an M.2 SSD.
The front pin assignment can be seen in the figure.
Article in other languages:
Review Date: 2025-07-20
