46030members
3262online
158048posts
Why does the camera not work correctly (smartphones / tablets)?
If you have problems with the camera of your smartphone or tablet, then maybe the following tips will help you:
Please note that there are different Android versions and therefore there may be deviations in the naming of the individual points.
Advice (only in supported countries):
With the error description you have provided our diagnostic app can determine if it is a fault.
Simply download the app to your device, start and if an error is detected you can directly trigger a repair order.
Article in other languages:
Review Date: 2023-09-05
