Why is there a cover on the inside of the microwave?
This cardboard cover is not a transport lock, but is intended as a splash guard to protect the vacuum runtime tube for generating electromagnetic waves (magnetron) inside the appliance. If this is removed or damaged, there is a risk of dirt or grease getting onto the electronics, increasing the risk of a short circuit and the risk of fire. To prevent this, you can purchase magnetron covers from independent dealers and insert them yourself.
The magnetron cover consists of a mica plate. Mica (in the form of artificial mica) is used as a cover in microwave ovens, you can find out more about mica plates here.
Damage caused by a missing cover is not covered by the warranty. If this is discovered after sending the unit to our workshop, you will receive a repair quotation (cost estimate) for which a charge will be made.
Examples of Mica plates
Example: Position Mica plate
Article in other languages:
Review Date: 2024-08-22
