MSN 20069710
There are 2 memory slots on the mainboard, each of which can hold 16 GB RAM. The maximum capacity is therefore 32 GB.
| Module: | 288 Pin-DIMM |
| Type: | SDRAM-DDR4 |
| Clock: | 3200 MHz |
| Voltage: | 1,2V |
⚠️Note⚠️ In the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB of memory is recognised. You can find more information on this on the Microsoft website.
If you have not yet installed a memory, this MSI-video may help you.
| Slot | Interface | Dimensions | Key(s) | Hints |
| 1 | PCIEx4GEN3 (M2_1) | 2242/2260/2280 | M Key | Intel Optane memory ready |
| 2 | for SATA SSD module (M2_2) | 2260/2280 | M Key | |
| 3 | 2230 | E Key | only WLAN |
If the M.2 SATA port (M2_2) is occupied, SATA port 1 is deactivated.
⚠️Note⚠️ For the fastening you need a screw with metric M2 thread and a length between 2.5 mm and 3.0 mm. The head should have a diameter of 4 mm to a maximum of 5 mm. If the screws are not available in local shops, you can find them in online shops.
The front PIN assignment can be taken from the illustration.
1x PCIe 4.01 x16
Depending on the CPU used
