46028members
3040online
158047posts
How do I increase the suction power of my 2in1 handheld vacuum cleaner MD 16911 / MD 18403 / MD 18418?
The suction power cannot be increased in manual operation without a handle.
You can insert the hand vacuum into the handle, switch it on, increase the suction power and then remove it during operation. The set suction power then remains at the set level.
⚠️Note⚠️ As soon as the hand vacuum is switched off, it is back to low level when switched on again.
ChangeLog:
Article in other languages:
Review Date: 2025-04-29
