How do I change the interior lighting of my refrigerator?
If you set the thermostat control to the 0 position, the appliance will now switch off. Now pull out the mains plug and then loosen the screw on the lamp cover with a Phillips screwdriver.
Now carefully bend the cover outwards with a flat-blade screwdriver and remove the cover.
Replace the faulty bulb, observing the technical data in the operating instructions. It is important that you pay attention to the dimensions of the glass bulb in order to be able to reattach the lamp cover correctly.
Visualisation of different light bulb sizes
Now replace the cover and secure it with the screw. Make sure that you only use light bulbs with an Voltage of 220-240 V.
⚠️Note⚠️ If your device is equipped with an LED or LED strip, this can only be replaced by the service technician.
ChangeLog:
Article in other languages:
Review Date: 2025-05-12
