46057members
4211online
158089posts
MSN 20069215
Intel CPUs of the Rocket Lake series for socket LGA 1200 can be installed.
There are 4 memory slots on the mainboard, each of which can hold 32 GB of RAM. The maximum capacity is therefore 128 GB.
| Module: | 288-Pin DIMM |
| Type: | SDRAM DDR4 |
| Clock: | 2933 MHz |
| Voltage: | 1,2 V |
| Feature: | no ecc support |
⚠️Note⚠️In the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB of memory is recognised. You can find more information on this on the Microsoft website.
| Slot | Connection | Size | Key(s) | Note |
| 1 | PCIe x4 Gen 4 | 2242, 2280 | M key | |
| 2 | PCIe x4 Gen 3 | 2242, 2280 | M key | |
| 3 | 2230 | E key | only WLAN |
| Designation | Number | Features |
| USB 2.0 | 2 | The USB ports are not colour-coded on this mainboard. The USB 2.0 ports are located below the LAN socket. |
| USB 3.2 Gen1 | 2 | The USB 3.2 Gen1 Type A ports are located on the left side of the bezel. |
| USB 3.2 Gen2 | 1 | Type-C |
| LAN (RJ45) | 1 | |
| Jack Audio (OFC) | 3 | 3,5 mm |
Article in other languages:
Review Date: 2025-08-17
