MSN 20069824
There are 2 memory slots on the mainboard, each of which can hold 16 GB of RAM. The maximum capacity is therefore 32 GB.
| Module: | 288 Pin-DIMM |
| Type: | SDRAM-DDR4 |
| Clock: | 3200 MHz |
| Voltage: | 1,2V |
⚠️Note⚠️ In the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB of memory is recognised. You can find more information on this on the Microsoft website.
If you have not yet installed a memory, this video from video of MSI may help you.
| Slot | Interface | Dimensions | Key(s) | Hints |
| 1 | PCIEx4GEN3 (M2_1) | 2242/2260/2280 | M Key | Intel Optane memory ready |
| 2 | 2230 | E Key | only WLAN |
⚠️Note⚠️ For the fastening you need a screw with metric M2 thread and a length between 2.5 mm and 3.0 mm. The head should have a diameter of 4 mm to a maximum of 5 mm . If the screws are not available in local shops, you can find them in online shops.
The front PIN assignment can be taken from the illustration.
1x PCIe 4.01 x16
1Depending on the CPU used
Article in other languages:
Review Date: 2025-08-16
