MSN 20068644
There are 4 memory slots on the mainboard each with 32 GB RAM. The maximum capacity is therefore 128 GB.
| Module: | 288-Pin DIMM |
| Type: | SDRAM-DDR4 |
| Speed: | 2133/2400/2666/2933 MHz |
| Voltage: | 1,2 |
| Feature: | no ECC-support |
⚠️Note⚠️ In the 32-bit editions of Windows operating systems, a maximum of approx. 3.2 GB of memory can be recognised. You can find more information on this on the Microsoft website.
| Slot | Interface | Dimensions | Keys | Hints |
| 1 | PCIe 4x | 2242, 2260, 2280, 22110 | M key | MB Designation (M2Q_SB) |
| 2 | PCIe 4x, SATA | 2242, 2260, 2280 | M key | MB Designation (M2A_SB) |
| 3 | 2242 | only WLAN (M2_Wifi) |
If the M.2 port 2 (M2A_SB) is equipped with a SATA M.2, the SATA port 0 is without function.
⚠️Note⚠️ For the fastening you need a screw with a metric M2 thread and a length between 2.5 mm and 3.0 mm. The head should have a diameter of 4 mm to a maximum of 5 mm. If the screws are not available in local shops, you can find them in online shops.
Note the correct polarity, otherwise the computer may not start.
Article in other languages:
Review Date: 2025-03-12
