EFI Boot Fix - doesn't help
18 REPLIES 18
ZAJDAN
Message 1 of 19
Message 1 of 19
Hello,
I have the known problem where a tablet boots into efi shell. So I try to use EFI Boot Fix .
Flash drive is formated as fat32, EFI Bott Fix files are placed on the flash drive. I connect the FlashDrive via OTG to tablet and powerOn the tablet.
The result is, that tablet doesn't start Android OS and again do the same problem. I captured a screenshot from the tablet durring the fixing process.
Thanks for any hints
Tags (2)
18 REPLIES 18
ZAJDAN
Message 11 of 19
Message 11 of 19
ZAJDAN
Message 12 of 19
Message 12 of 19
@daddle
I am not sure if I understand You correctly (german language I translate via translator), but Yes I use OTG reduction with three different USB sticks(512MB, 6GB, 8GB) all formated as FAT
do You think will be good to try use USB HUB?
tablet->OTG->USB HUB->USB Stick
Message 13 of 19
Message 13 of 19
No, not seriously. Did you use an USB-hub flashing the recovery-package?
ZAJDAN
Message 14 of 19
Message 14 of 19
@daddle
Not, everytime it was connected via OTG reduction, about the hub it was just idea if it will helps.
Message 15 of 19
Message 15 of 19
@ZAJDAN
Here in your flash failure-protocol it says "error":
error: cannot load '/efilinux-.efi': No such file or directory
I think the error text should be:
error: cannot load '/efilinux-user.efi': No such file or directory
That is maybe the reason für your bootorder-error; the efilinux-user.efi file was never found nor flashed, because the flash.sh looks instead for the  "/efilinux-user .efi" for the "/efilinux- .efi" ?
The flash.sh says:
 "./fastboot flash osloader $OUT/efilinux-$TARGET_BUILD_VARIANT.efi"
Did you mess around with the " $OUT/efilinux-$TARGET_BUILD_VARIANT.efi" line, and gave this the possible wrong error-text? Or is the efilinux-path wrongly written??
(Although later on the esp.zip is flashed, which also contains the identical files in  Boot/ bootx64.efi and in /Intel/efilinux.efi; but do not know if bin the same position.
May be @TheDoctor could check this
ZAJDAN
Message 16 of 19
Message 16 of 19
@daddle
if You will read mentioned thread completely, You will see, that I solved this problem about load necessary files.
in the script is something wrong with variable $OUT
I could also try windows version 😞
Message 17 of 19
Message 17 of 19
Off course I read. Otherwise I couldn't have noticed the missing "user" in error-text:
"error: cannot load '/efilinux-.efi': No such file or directory"
The  $TARGET_BUILD_VARIANT isn't replaced by "user" in error. Should it be?
Like I said in the beginning, I do not know much about Linux or Android.
May be by replacing standard $OUT with your long path-name (too long?) you made an error or typo?
And yes, reflashing the recovery-package in Windows you should try; but for safety reason make a new download before.
ZAJDAN
Message 18 of 19
Message 18 of 19
when I replace the $OUT everywhere where the variable is , with my absolute path /home/zajdan/Downloads/medion-p7332/
the mentioned files are loaded without error
ZAJDAN
Message 19 of 19
Message 19 of 19
I tried recovery package also from windows, but during process stage 2 each step ends with status FAILED
https://community.medion.com/t5/Tablet/ANDROID-RECOVERY-PAKET/m-p/42058/highlight/false#M8809
18 REPLIES 18
