EFI Boot Fix - doesn't help
18 ANTWOORDEN 18
ZAJDAN
Bericht 1 van 19
16.719 Weergaven
Bericht 1 van 19
16.719 Weergaven
Hello,
I have the known problem where a tablet boots into efi shell. So I try to use EFI Boot Fix .
Flash drive is formated as fat32, EFI Bott Fix files are placed on the flash drive. I connect the FlashDrive via OTG to tablet and powerOn the tablet.
The result is, that tablet doesn't start Android OS and again do the same problem. I captured a screenshot from the tablet durring the fixing process.
Thanks for any hints
Tags (2)
18 ANTWOORDEN 18
ZAJDAN
Bericht 11 van 19
8.351 Weergaven
Bericht 11 van 19
8.351 Weergaven
ZAJDAN
Bericht 12 van 19
8.350 Weergaven
Bericht 12 van 19
8.350 Weergaven
@daddle
I am not sure if I understand You correctly (german language I translate via translator), but Yes I use OTG reduction with three different USB sticks(512MB, 6GB, 8GB) all formated as FAT
do You think will be good to try use USB HUB?
tablet->OTG->USB HUB->USB Stick
Bericht 13 van 19
8.334 Weergaven
Bericht 13 van 19
8.334 Weergaven
No, not seriously. Did you use an USB-hub flashing the recovery-package?
ZAJDAN
Bericht 14 van 19
8.330 Weergaven
Bericht 14 van 19
8.330 Weergaven
@daddle
Not, everytime it was connected via OTG reduction, about the hub it was just idea if it will helps.
Bericht 15 van 19
8.326 Weergaven
Bericht 15 van 19
8.326 Weergaven
@ZAJDAN
Here in your flash failure-protocol it says "error":
error: cannot load '/efilinux-.efi': No such file or directory
I think the error text should be:
error: cannot load '/efilinux-user.efi': No such file or directory
That is maybe the reason für your bootorder-error; the efilinux-user.efi file was never found nor flashed, because the flash.sh looks instead for the  "/efilinux-user .efi" for the "/efilinux- .efi" ?
The flash.sh says:
 "./fastboot flash osloader $OUT/efilinux-$TARGET_BUILD_VARIANT.efi"
Did you mess around with the " $OUT/efilinux-$TARGET_BUILD_VARIANT.efi" line, and gave this the possible wrong error-text? Or is the efilinux-path wrongly written??
(Although later on the esp.zip is flashed, which also contains the identical files in  Boot/ bootx64.efi and in /Intel/efilinux.efi; but do not know if bin the same position.
May be @TheDoctor could check this
ZAJDAN
Bericht 16 van 19
8.319 Weergaven
Bericht 16 van 19
8.319 Weergaven
@daddle
if You will read mentioned thread completely, You will see, that I solved this problem about load necessary files.
in the script is something wrong with variable $OUT
I could also try windows version 😞
Bericht 17 van 19
8.314 Weergaven
Bericht 17 van 19
8.314 Weergaven
Off course I read. Otherwise I couldn't have noticed the missing "user" in error-text:
"error: cannot load '/efilinux-.efi': No such file or directory"
The  $TARGET_BUILD_VARIANT isn't replaced by "user" in error. Should it be?
Like I said in the beginning, I do not know much about Linux or Android.
May be by replacing standard $OUT with your long path-name (too long?) you made an error or typo?
And yes, reflashing the recovery-package in Windows you should try; but for safety reason make a new download before.
ZAJDAN
Bericht 18 van 19
8.309 Weergaven
Bericht 18 van 19
8.309 Weergaven
when I replace the $OUT everywhere where the variable is , with my absolute path /home/zajdan/Downloads/medion-p7332/
the mentioned files are loaded without error
ZAJDAN
Bericht 19 van 19
8.282 Weergaven
Bericht 19 van 19
8.282 Weergaven
I tried recovery package also from windows, but during process stage 2 each step ends with status FAILED
https://community.medion.com/t5/Tablet/ANDROID-RECOVERY-PAKET/m-p/42058/highlight/false#M8809
18 ANTWOORDEN 18
