EFI Boot Fix - doesn't help
18 RÉPONSES 18
ZAJDAN
Message 1 sur 19
17 260 Visites
Message 1 sur 19
17 260 Visites
Hello,
I have the known problem where a tablet boots into efi shell. So I try to use EFI Boot Fix .
Flash drive is formated as fat32, EFI Bott Fix files are placed on the flash drive. I connect the FlashDrive via OTG to tablet and powerOn the tablet.
The result is, that tablet doesn't start Android OS and again do the same problem. I captured a screenshot from the tablet durring the fixing process.
Thanks for any hints
Balises (2)
18 RÉPONSES 18
ZAJDAN
Message 11 sur 19
8 644 Visites
Message 11 sur 19
8 644 Visites
ZAJDAN
Message 12 sur 19
8 643 Visites
Message 12 sur 19
8 643 Visites
@daddle
I am not sure if I understand You correctly (german language I translate via translator), but Yes I use OTG reduction with three different USB sticks(512MB, 6GB, 8GB) all formated as FAT
do You think will be good to try use USB HUB?
tablet->OTG->USB HUB->USB Stick
Message 13 sur 19
8 627 Visites
Message 13 sur 19
8 627 Visites
No, not seriously. Did you use an USB-hub flashing the recovery-package?
ZAJDAN
Message 14 sur 19
8 623 Visites
Message 14 sur 19
8 623 Visites
@daddle
Not, everytime it was connected via OTG reduction, about the hub it was just idea if it will helps.
Message 15 sur 19
8 619 Visites
Message 15 sur 19
8 619 Visites
@ZAJDAN
Here in your flash failure-protocol it says "error":
error: cannot load '/efilinux-.efi': No such file or directory
I think the error text should be:
error: cannot load '/efilinux-user.efi': No such file or directory
That is maybe the reason für your bootorder-error; the efilinux-user.efi file was never found nor flashed, because the flash.sh looks instead for the  "/efilinux-user .efi" for the "/efilinux- .efi" ?
The flash.sh says:
 "./fastboot flash osloader $OUT/efilinux-$TARGET_BUILD_VARIANT.efi"
Did you mess around with the " $OUT/efilinux-$TARGET_BUILD_VARIANT.efi" line, and gave this the possible wrong error-text? Or is the efilinux-path wrongly written??
(Although later on the esp.zip is flashed, which also contains the identical files in  Boot/ bootx64.efi and in /Intel/efilinux.efi; but do not know if bin the same position.
May be @TheDoctor could check this
ZAJDAN
Message 16 sur 19
8 612 Visites
Message 16 sur 19
8 612 Visites
@daddle
if You will read mentioned thread completely, You will see, that I solved this problem about load necessary files.
in the script is something wrong with variable $OUT
I could also try windows version 😞
Message 17 sur 19
8 607 Visites
Message 17 sur 19
8 607 Visites
Off course I read. Otherwise I couldn't have noticed the missing "user" in error-text:
"error: cannot load '/efilinux-.efi': No such file or directory"
The  $TARGET_BUILD_VARIANT isn't replaced by "user" in error. Should it be?
Like I said in the beginning, I do not know much about Linux or Android.
May be by replacing standard $OUT with your long path-name (too long?) you made an error or typo?
And yes, reflashing the recovery-package in Windows you should try; but for safety reason make a new download before.
ZAJDAN
Message 18 sur 19
8 602 Visites
Message 18 sur 19
8 602 Visites
when I replace the $OUT everywhere where the variable is , with my absolute path /home/zajdan/Downloads/medion-p7332/
the mentioned files are loaded without error
ZAJDAN
Message 19 sur 19
8 575 Visites
Message 19 sur 19
8 575 Visites
I tried recovery package also from windows, but during process stage 2 each step ends with status FAILED
https://community.medion.com/t5/Tablet/ANDROID-RECOVERY-PAKET/m-p/42058/highlight/false#M8809
18 RÉPONSES 18
