Flashing using a CH341A??
4 REPLIES 4
boi5643
Message 1 of 5
Message 1 of 5
I have an Erazer Beast X25-MD and the BIOS is completely bricked...
I have downloaded the BIOS from a link supplied by @Major_ToM which I found here: https://community.medion.com/t5/ERAZER-Gaming-NBs/Bios-Update-MEDION-ERAZER-Beast-X25-V1-231/m-p/132...
Can I flash the ROM within the download to the BIOS chip after converting it to a BIN file using the CH341A? and if not, why not? or is there a better way to do this? the laptop is currently completely bricked, I explained in my previous post all the detail about the laptop and the events leading up to this.
Thanks!
4 REPLIES 4
Message 2 of 5
Message 2 of 5
@boi5643
If you open the F-bat with an editor, it says at the end before flashing begins:
@echo off
@cls
@echo WARNING: This utility will reprogram the whole SPI Flash chip which
@echo WARNING: includes system BIOS, TXE or ME firmware!!!
@echo WARNING: DO NOT continue unless you are 100% sure you want to do this.
@echo WARNING: To stop, turn off your computer and remove the update media,
@echo WARNING: or do not run THIS SCRIPT.
@pause
So I guess you could make use of it, and rename the rom file to a bin file
But to be completely sure  you should wait for confirmation from  @Major_ToM .
Cheers, daddle
Mastermind
Message 3 of 5
Message 3 of 5
Hi @boi5643 and sorry for the late reply.
Yes, you start the update process by executing the F.bat file from the unzipped archive by right-clicking as administrator (in Windows environment).
Cheers
Message 4 of 5
Message 4 of 5
@Major_ToM
Hallo Major, das war nicht seine Frage. Sein Rechner ist "bricked"  und startet also nicht mehr, wie er schreibt. Dann dann kann er keine F.bat nutzen. In Post 1 fragt er ob das ROM im Download eine komplettes ROM ist,  und er es in eine bin file umbenennen kann.
Gruß, daddle
Mastermind
Message 5 of 5
Message 5 of 5
Hi @daddle & @boi5643 ,
sorry for the first misunderstanding, I unfortunately have no product sample in hand, so that I´m only able to "assume, that it could" work.
Otherwise we would have to get the machine to the service center, what would end up in a cost estimate.
Please let us an the Community know, if you were successfull running the update manually.
Cheers
4 REPLIES 4
