I cant find bios Medion laptop E14409 (MD62389) (MSN30033663)
3 REPLIES 3
Palote2024
Message 1 of 4
Message 1 of 4
I think I changed some parameters in the bios and now laptop cant boot. The screeen is black and cant enter at bios . I try to install a new bios but I cant find. I hope someone find me .
Thanks in advance
3 REPLIES 3
Message 2 of 4
Message 2 of 4
Hi @Palote2024 and welcome
Open the device and disconnect the battery and CMOS battery for 10 minutes. After reconnecting, then go into BIOS and load optimized default settings.
bye Fishtown
Palote2024
Message 3 of 4
Message 3 of 4
Hello again and thanks
buT I not want open the laptop because still in warranty so I think will be more easy add a new bios but I cant find.
I not understand why I have all drivers but bios not exist in medion web
Message 4 of 4
Message 4 of 4
@Palote2024
Sorry, but this is non quite correct.  If the Bios is corrupt or even just disguised, it would be better before flashing a Bios update, to have it set to defaults. And usually with the most Medion bios-updates you have to be in Windows to flash a bios.
But actually with a Medion OEM Bios  there are normally no  such settings which blocks entering the bios, or darkens the screen.
Did you see some bios messages on the screen, or does it stay completely black?
So I guess or you did something wrong, or not using the right commands to enter Bios. If pressing the F2 key doesn't work then try tapping the F10 key when you switch the PC on, or  press first and hold the F10 key and, then switch the laptop on (alternativly it could be with your Laptop the F8 or F7 key.). Test them all.
If it works  you get the isolated boot menu on the screen, the lower entry (Bios Setup), gives you access to the  bios.
Cheers, daddle
3 REPLIES 3
